98 gmc jimmy 4 wd
DAVIDWRIG1990
I have a 1998 gmc gimmy with 4 wheel drive and it wont enguage. when I press the button the light might come on but wont flash.I have noticed when I unhook battery for few seconds then hook it back up and try it the light will blick for a couple of seconds then will stop and the 2 hi will do come back on. It dosent even try to enguage so im not sure what it is.
Jan 4, 2006 at 11:44 AM
DAVIDWRIG1990
could i put it on a dignostic to see . is the part expensive and is this a common problem thanks also is this a hard part to replace
Jan 5, 2006 at 11:16 AM
GSINALTUS
My 2000 GMC Z71 was doing the same, except the Service 4WD light came on as well. Found out that the actual switch was a common problem for this.
Jan 10, 2006 at 6:57 AM
