2003 GMC Jimmy lug nuts
2003 GMC JIMMY
GARY HENRY
Tires and Wheels problem
2003 GMC Jimmy 6 cyl Four Wheel Drive Automatic
I have lost the security key for the lug nuts. How do I get them off without damaging the bearings?
Dec 28, 2008 at 1:44 AM
SWILLIAMS
  • 597 POSTS
Visit a tire shop and have them see if they have one that will fit OR if not have them use one of the toothed removal sockets that can be purchased all over the place. It is a tool that looks like a socket with file teeth inside it. You drive it on with a hammer and then remove the locking nuts. If you have the type with the security sleeve you remove one of the other lug nuts, then use a welder to lock the sleeve, then use the above tool.
Dec 29, 2008 at 12:03 PM
