2001 GMC Jimmy turn signals and brake lights
NINETAILS
Electrical problem
2001 GMC Jimmy 6 cyl Two Wheel Drive Automatic
my right turn signal on my 2001 gmc jimmy slt stoped blinking, it comes on and stays on, i changed the flasher relay with a new one with no avail, while checking the bulbs and sockets on the right side i noticed that the brake lights are also staying on as well, the only time they go off is when useing the left turn signal.. im afraid im at a bit of a loss with this one, can any body offer any help?
EDIT: i have also checked ALL fuses, twice, and have found nothing
May 31, 2009 at 8:12 AM
JDL
  • 16,098 POSTS
Hello, did you check the bulbs at the front, on the right side? Also, I believe the turn and lower stop lamps use the same bulb filament just not at the same time. The lower brake lites are wired through the the turn switch.
May 31, 2009 at 8:48 AM
NINETAILS
i did check all the bulbs on the right side, and in regards to the signal switch the more i lookinto this problem the more im seeing that seems to be the most likely culprate, i just dont want to drop that kind of money unless im 100% sure.
EDIT/UPDATE: I just tinkered with it some more and found that if i held the hazered button just right the brake lites whent off and the right signal started blinking again.. ssooooooo, what do you all think?
May 31, 2009 at 9:51 AM
