Changed the front and back brake pads but still have the brake light on
Jul 20, 2010 at 5:48 PM
BLACKOP555
✓Experienced Mechanic
make sure your wheel speed sensors are properly connected and the gap between the tone ring and the wheel speed sensor is in spec and uniform between them all. you can jack one wheel up at a time and spin wheels and see what ac voltage they are puting out. they should all put out same voltage at same speed.
