I then proceeded to do a 90k mile tuneup.
The usual cap, rotor, plugs, wires, fuel, air and pcv.
I was unable to reach the #3 plug as the steering rod is in the way, any hints?
After the tuneup the car had a slight miss on acceleration.
I used all AC Delco and inspected all the plugs before installing. I also swapped out the old cap, rotor and coil wire but got the same issue.
Drove it about 5 miles and it starting popping a bit, hope the cat is ok!
Please advise
Thanks,
Rich
SPONSORED LINKS
Wednesday, January 16th, 2008 AT 1:48 AM
