2000 GMC Jimmy
BRADLEYF29
  • 2000 GMC JIMMY
  • 6 CYL
  • 4WD
  • 150,000 MILES
My engine will only start if u pump the gas pedal, it will run as long as u give the engine gas. After you get off the gas it will sputter and die
Monday, September 6th, 2010 AT 3:59 PM
HMAC300
  • 48,601 POSTS
Check your fuel pressure and replace your fuel filter.
Wednesday, September 15th, 2010 AT 6:07 PM
BRADLEYF29
Thnx, but it wound up needing a new MAP sensor
Wednesday, September 15th, 2010 AT 7:59 PM
