The filter could have contributed to the fuel pump failure but won't be the direct cause of the issue. It should be changed automatically with the new pump to protect it. When they get restricted, they overwork the pump. The pump is strong enough to push through it but won't be for long.
Make sure you verify the contacts in the plug are good and tight too. They have a known problem with that.
SPONSORED LINKS
Monday, August 23rd, 2010 AT 5:09 PM
