1998 GMC Jimmy Nightmare problem!
15,600 MILES • 6 CYL • 4WD • AUTOMATIC
SNOWBOUNDBABE
I have been having an intermittent electrical problem. My gauges will just go out and dash lights. I will be doing 60 and the car will miss a little, but keep going. The gauges will jump back up and the car will do a systems check while I am doing 60. Today I started the car and no gauges and a service engine code for component slipping in transmission. Nothing is slipping, but that code is stored and keeps coming back. Today after I started and got no gauges, I shifted into gear and I got the gauges back and a service engine code(the slipping component again and I drove to work with no overdrive) Tried to have a new BCM installed that I bought online to no avail, but the car was nice and warm and dry. Drove home with the code gone, overdrive, and all my gauges. Happens most after a car wash when it goes down to zero degrees.
Feb 6, 2008 at 11:02 AM
CHEIFJEFF
[quote:850a440421="snowboundbabe"]Electrical problem
1998 GMC Jimmy 6 cyl Four Wheel Drive Automatic 156,00 miles
I have been having an intermittent electrical problem. My gauges will just go out and dash lights. I will be doing 60 and the car will miss a little, but keep going. The gauges will jump back up and the car will do a systems check while I am doing 60. Today I started the car and no gauges and a service engine code for component slipping in transmission. Nothing is slipping, but that code is stored and keeps coming back. Today after I started and got no gauges, I shifted into gear and I got the gauges back and a service engine code(the slipping component again and I drove to work with no overdrive) Tried to have a new BCM installed that I bought online to no avail, but the car was nice and warm and dry. Drove home with the code gone, overdrive, and all my gauges. Happens most after a car wash when it goes down to zero degrees.[/quote:850a440421] check the pin conector from in side to out side of passenger compartment
Mar 5, 2008 at 11:36 AM
SNOWBOUNDBABE
it was ignition switch just so everyone knows. had repair manual-everyone was stumped.I am replacing ignition lock cylinder also
Mar 5, 2008 at 11:46 AM
