Check the fuel pressure and flow rate. Also check for residual pressure. If you have good pressure but low flow the pump is going bad. If you have good pressure and flow but the residual pressure drops fast test the pressure regulator for proper operation. If the filter hasn't been changed in a while change it as well.
SPONSORED LINKS
Wednesday, July 16th, 2008 AT 10:27 PM
