1996 GMC Jimmy engine stalls when hot, after 2 hours on roa
GENEK
  • 1996 GMC JIMMY
  • 6 CYL
  • 4WD
  • 115,000 MILES
After a few hours car stalls, takes 10 min to cool then it runs, also sometimes stalls at idle, getting worse, stalls with increaseing frequency, replaced voltage regulator, word on street it maybe something with the fuel-throttle something, someone else said the catalatic converter, makes no sense to me. Help, please
Wednesday, August 13th, 2008 AT 1:34 PM
SWILLIAMS
  • 597 POSTS
Check the fuel pump for pressure AND volume. Also test for residual pressure (the pressure held when you turn the key off and the fuel pump stops.) Poor volume or inability to hold pressure will cause the symptoms your seeing.
Tuesday, August 19th, 2008 AT 2:46 PM
