1996 GMC Jimmy
KAW4240
  • 1996 GMC JIMMY
  • 6 CYL
  • 4WD
  • 260,000 MILES
Needing to replace the upper & lower intake gasket
what is the best way to set the distubitor back to be on time
are there any special tools needed for the replacement and touque specs
Saturday, October 4th, 2008 AT 2:16 PM
  • 109,885 POSTS
Hi:
There are no special tools required to replace the distributor. However, the distributor needs replaced in the correct place for timing.
Because of the extent of what you're doing, I suggest that you purchase a manual for your vehicle. The manual will have all the information you need and pictures to help guide you.
If you have any questions, let me know.
Tuesday, October 14th, 2008 AT 1:00 PM
