You need to determine what is missing. Spark? Fuel? Timing/compression? Or any combination of the three.
When it is cranking and not starting, check for sprak with a spark tester. You can shoot some carb cleaner into the throttle and see if a lack of fuel is present ( assuming it is only a lack of fuel.) PRessure test the fuel system when it isn't starting for spec. ( The fuel pump connector should have been replaced when doing the pump. Was it?
There may be a lack of signal from a crankshaft sensor happening. But you need to confrm what is lacking before testing further.
SPONSORED LINKS
Monday, August 18th, 2008 AT 5:50 AM
