1995 GMC Jimmy 1995 GMC Jimmy temperature gauge reading too
1995 GMC JIMMY
161,000 MILES • 6 CYL • 4WD • AUTOMATIC
BENEYCE
Hi, I have a 1995 GMC Jimmy. I have replaced the water pump and thermostat due to a percieved overheating problem. I have a snapon mt2500 that I hooked up to the computer. The temperature is running from 185 degrees to about 195 on the scan took. I replaced the thermostat with a 180 degree temp. No over heating. It is cooling just as it should. The gauge reads about 250 degrees. Is this a common problem? How can I fix this problem. temp sending unit? or different gauge cluster? Any ideas? Thanks -Ben
Aug 24, 2008 at 2:13 PM
