1995 GMC Jimmy
LOGAN_JIMMY
  • 1995 GMC JIMMY
  • 6 CYL
  • 4WD
  • 201,000 MILES
I have a 1995 GMC Jimmy with a little over 201,000 miles. When I start it up it shows the "service engine light" and the "check guages light". It takes a few tries to actually get it started up and going. Im not sure what can cause that or how to fix it.(It's my first car). And when I get driving it takes quite a long time to shift out of first and sometimes out of second.
Saturday, March 27th, 2010 AT 2:31 PM
MIDDY
  • 30 POSTS
If you have some wrench-monkey friends, ask them if they have an engine code reader. They're pretty simple to use. Plug in to a socket underneath the driver-side dash, and you can read the codes that the vehicle is outputting. This will give you an idea what the problem is. If you can't find a friend with a reader, you might call some of your local auto parts stores to see if they would read your engine codes for you.
The transmission thing, you may have done this already, but you should check your transmission fluid first if it seems delayed shifting. That is a 4L60E transmisison. In that era, those transmissions were notorious for a failing sun shield. When that piece fails, it turns to a metallic gritty pollutant in your fluid and trashes the transmission. If this has happened to you, you'll be able to feel the gritty substance in the fluid on the end of your transmission dipstick.
Saturday, March 27th, 2010 AT 6:04 PM
