1994 GMC Jimmy idleing high
FIREFIGHTER47
  • 9 POSTS
Engine Mechanical problem
1994 GMC Jimmy 6 cyl Four Wheel Drive Automatic
i have a gmc jimmy that i have just got running agian and it idles way to high how can i fix that
Feb 6, 2009 at 1:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First thing to do is check for a vacuum leak. Pay particular attention to the EGR valve area, in intake manifold.
Let me know how the vacuum hoses and connections are and I will follow up.
Thanks for using 2CarPros.com!
Feb 6, 2009 at 1:53 PM
FIREFIGHTER47
  • 9 POSTS
i have checked the vacume hoses and i thought the egr valve was under the manifold
[quote:d5564fadec="bluelightnin6"]First thing to do is check for a vacuum leak. Pay particular attention to the EGR valve area, in intake manifold.
Thanks for using 2CarPros.com![/quote:d5564fadec]
Feb 6, 2009 at 2:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
EGR valve is located center, upper engine area, front of intake manifold, passenger side of water outlet, mounted in intake manifold.
Feb 6, 2009 at 2:11 PM
FIREFIGHTER47
  • 9 POSTS
how can i check if its working right
[quote:ec091158cd="bluelightnin6"]EGR valve is located center, upper engine area, front of intake manifold, passenger side of water outlet, mounted in intake manifold.[/quote:ec091158cd]
Feb 6, 2009 at 2:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
EGR valve would cause rough idle and stalling in most cases, not high idle. However, to check EGR valve function, have someone idle the parked vehicle with the brake on while you examine the plunger shaft to see if it is stuck open. Also, while engine warm, rev up engine and watch to see if valve is moving.
Feb 6, 2009 at 2:46 PM
FIREFIGHTER47
  • 9 POSTS
the jimmy is idleing way high not rough
[quote:7260e84727="bluelightnin6"]EGR valve would cause rough idle and stalling in most cases, not high idle. However, to check EGR valve function, have someone idle the parked vehicle with the brake on while you examine the plunger shaft to see if it is stuck open. Also, while engine warm, rev up engine and watch to see if valve is moving.[/quote:7260e84727]
Feb 7, 2009 at 1:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
High idle can be caused by several things. A list of possible causes and corrections are below.
Ensure throttle linkage and/or throttle position sensor do not stick or bind.
Check park/neutral switch circuit. Ensure park/neutral switch is properly adjusted.
Check exhaust sytem for restrictions, such as a damaged or collapsed pipe, muffler or catalytic converter.
Ensure initial ignition timing is properly set.
Disconnect MAP sensor. If condition is correct, replace sensor.
Check engine idle speed (both base and PCM idle).
Check Idle Air Control (IAC) system. Check for foreign material in IAC bore.
Check power steering pressure switch circuit.
Feb 7, 2009 at 11:01 AM
FIREFIGHTER47
  • 9 POSTS
i fixed my idle problem and now when i put it in gear it doesnt want to go and you push the gas and it back fires and cuts out
[quote:1e0277ed38="bluelightnin6"]High idle can be caused by several things. A list of possible causes and corrections are below.
Check power steering pressure switch circuit.[/quote:1e0277ed38]
Feb 7, 2009 at 11:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Information about backfiring can be found at the link below. .
https://www.2carpros.com/first_things/why_does_an_engine_backfire.htm
After checking out these steps let me know if you still have the problem
Feb 7, 2009 at 11:31 AM
FIREFIGHTER47
  • 9 POSTS
could the fuel filter being cloged cause the back fireing and i put 8 mm wires on it insted of the 7mm wires that were on it could it be the problem
[quote:be93ced49a="bluelightnin6"]Information about backfiring can be found at the link below. .
Thanks for using 2CarPros.com![/quote:be93ced49a]
Feb 7, 2009 at 12:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, clogged fuel filter will cause backfiring. Wires should be OEM parts and recommended size. If they are smaller than recommended size then yes, they could cause backfiring. Plugs will not receive enough to ignite all of the fuel which in turn will cause backfire. I would start with swapping out those wires before replacing the fuel filter.
Feb 7, 2009 at 12:29 PM
FIREFIGHTER47
  • 9 POSTS
i was thinking bout switching out the filter changing the wires, plugs cap and roter all at the same time
[quote:6f833c4c75="bluelightnin6"]Yes, clogged fuel filter will cause backfiring. Wires should be OEM parts and recommended size. If they are smaller than recommended size then yes, they could cause backfiring. Plugs will not receive enough to ignite all of the fuel which in turn will cause backfire. I would start with swapping out those wires before replacing the fuel filter.[/quote:6f833c4c75]
Feb 7, 2009 at 12:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Oh okay, that would be even better. I was just trying to save money but if you can afford it then I would definitely replace it all. Even if fuel filter isn't the problem it will give you better performance and much better fuel mileage with a new filter.
Feb 7, 2009 at 12:40 PM
FIREFIGHTER47
  • 9 POSTS
ya its gona cost me about 50 dollars to replace all the wires and all that so i think ill just do that the only other problem i am haveing is that when i put it into gear that it doesnt want to move unless you get the rpms way up any sugestions
[quote:dbd4d13848="bluelightnin6"]Oh okay, that would be even better. I was just trying to save money but if you can afford it then I would definitely replace it all. Even if fuel filter isn't the problem it will give you better performance and much better fuel mileage with a new filter.[/quote:dbd4d13848]
Feb 7, 2009 at 12:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First check your ATF (auto tranny fluid). If fluid is burnt or low then replace it and fill properly. If the fluid is good then the tranny will more than likely need overhauled. Having to rev the engine to get the transmission to move sounds like a worn out hydraulic front pump or something is really wrong with the gears themselves.
Feb 7, 2009 at 1:08 PM
FIREFIGHTER47
  • 9 POSTS
i thought that it might be that it was low because that is the only thing i havent checked yet
[quote:5738b7918b="bluelightnin6"]First check your ATF (auto tranny fluid). If fluid is burnt or low then replace it and fill properly. If the fluid is good then the tranny will more than likely need overhauled. Having to rev the engine to get the transmission to move sounds like a worn out hydraulic front pump or something is really wrong with the gears themselves.[/quote:5738b7918b]
Feb 7, 2009 at 1:11 PM
