1992 GMC Jimmy just died
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
JETHRO1058
on a warm day i stoped at a light water from snow melting on foof ran down tha A piler on to the dash 5 to 6 miles as i was driving down the highy way it just shut off it has plenty of spark plenty of gas fuses are all good (all the ones i could find if their are more then the ones in fuse box i dont know about them)did not smell any burnt wires dont know where gm puts thier circuit brakers anything would help
Feb 26, 2008 at 9:35 AM
2CARPRO JACK
  • 11,533 POSTS
What side of the dash? If I remember correctly the PCM is on the pass side of that truck. Be sure it ddint get wet, they really dont do well in water.....lol
You say plenty of gas.... are the injectors spraying? (this is TBI? 8th digit of vin is Z?)
Feb 26, 2008 at 11:50 PM
JETHRO1058
sorry its a 94 water went on drivers side
Feb 27, 2008 at 3:17 AM
2CARPRO JACK
  • 11,533 POSTS
If there is a fuse/relay block under the dash on that side, see if any of the fuses are wet.Try spraying a little carb cleaner in the throttle bore to se if it will run
Feb 27, 2008 at 10:53 AM
