1992 GMC Jimmy
BUTTMONKEY
  • 1992 GMC JIMMY
1992 GMC Jimmy 4 cyl Four Wheel Drive Automatic
transmission is shifting late and check engine light came on use a key code and got the codes 32 and 43 need to know what the sensors are for those codes
Monday, September 27th, 2010 AT 8:37 PM
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Manifold Absolute Pressure Sensor Circuit (High Sig.)
34 Manifold Absolute Pressure Sensor Circuit (Low Sig.)
42 Electronic Spark Timing (EST) Circuit
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 Faulty PROM
54 Fuel Pump Circuit (Low Voltage)
55 ECM Error
Tuesday, September 28th, 2010 AT 4:53 AM
