1991 GMC Jimmy instalation of a fake pulley on the A/C moun
BRADJIMMY
  • 1991 GMC JIMMY
  • 6 CYL
  • 203,279 MILES
The a/c motor broke, so we need to insall a fake pulley on the a/c motor bracket. So wihich hole does the pulley go on the bracket so that the serpintine belt fits(there is only one size serpintine belt for this make and model)?
Thursday, November 5th, 2009 AT 9:00 AM
RACEFAN966
  • 5,029 POSTS
Ok all you need to do is remove the a/c compressor and any lines that you want to remove and plug the ends off so it you want it can be put back together if you want to replace the a/c later. Then go to your local Napa auto parts store and get part number 600-1802, this is an a/c bypass pulley so your belt won't change. Here is a pic.
https://www.2carpros.com/forum/automotive_pictures/249564_257130_1.jpg
Thursday, November 5th, 2009 AT 10:37 AM
