1987 GMC Jimmy panel and interior lights
1987 GMC JIMMY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
RIVERMEN6
im having a problem, my panel lights have shut off and my interior lights are staying on. ive have checked the fuses they are all fine,and i checked the light adjustment its fine also.Do you have any suggestions? Thanks
Mar 27, 2009 at 4:05 PM
IMPALASS
  • CAR REPAIR CONTRIBUTOR
  • 3,112 POSTS
Hello –
To better assist you your model is the Jimmy V1500, yes? Also what is your engine size in liter and the 8th digit of your VIN.
So if I understand you…………your interior lights. When you normally open the door the lights automatically come on. Then you shut the door and they go off. But currently when you open the door and shut it they stay on without turning off.
Your cluster/dash lights are totally out. When you turn your lights on at night, nothing on the dash lights up?
Mar 28, 2009 at 4:02 PM
RIVERMEN6
it is a 4.3 liter v6 and the 8th digit in the vin is W
Apr 1, 2009 at 12:04 PM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info………..
So I was correct on my questions back to you?
So if I understand you…………your interior lights. When you normally open the door the lights automatically come on. Then you shut the door and they go off. But currently when you open the door and shut it they stay on without turning off. Is your door ajar light on?
HEADLIGHT SWITCH
("C" & "K" Series)
1. Disconnect negative battery cable. Reach behind instrument panel and remove headlight switch knob and shaft by depressing retaining button. Remove trim panel and bezel.
2. Disconnect headlight switch wiring harness. Remove headlight switch. To install, reverse removal procedure.
I don’t even have a wiring diagram for this. My thought is to check the electrical connector for 12V at the headlight switch. If you have it then your switch may be bad since you have checked your fuses.
Still let me know about the door ajar light and the way the interior lights work per my question above.
Apr 2, 2009 at 9:01 PM
