2007 GMC Envoy ignition switch
2007 GMC ENVOY
CHRISJACOBS12
2007 GMC Envoy 6 cyl Two Wheel Drive Automatic
ignition switch wont move at all when trying to turn car on
Feb 11, 2010 at 7:58 PM
CARSANDAIRPLANES
  • 19 POSTS
Someone has probably damaged the wafer-tumblers inside the Ignition Lock Cylinder, preventing the side-bar from dropping and allowing the cylinder to turn. It is surprising how easy it is to damage these tumblers by simply sticking the wrong key in the cylinder. You can request the procedure to remove the cylinder from me if you can somehow get it to turn, but you are best off calling a reputable locksmith.
Mar 14, 2010 at 2:30 PM
