2004 GMC Envoy CODE P1680
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
JRIOS
MESAGE CODE P1680
PROBABLE CAUSES
Jan 29, 2009 at 3:04 AM
BRIAN 1
  • 1,030 POSTS
Some customers may comment on the Service Engine Soon Light coming on. Upon investigation, the technician may find a P1680 diagnostic trouble code.
Correction
Check the resistance of the accelerator pedal position sensors,If the resistance of the accelerator pedal position sensor is within the specifications shown then reprogram the PCM with the latest calibration.If the resistance of the accelerator pedal position sensor is within the specifications shown then replace the PCM. If the resistance of the accelerator pedal position sensor is outside the specifications shown then continue with the diagnostics for DTC P1680.post back with what you find.
Jan 29, 2009 at 4:03 AM
