Last weekend I drove my truck and upon arriving at my destination I heard a subtle "clicking" noise. It sounded like my lifters. I checked my oil level, which was fine. On Monday, I drove the truck a few blocks and the noise became very loud "clicking and knocking". I have researched the symptom online and found that "piston slapping" is common for GM vehicles between 98-2003 due to engine building practices. Although GM has called this symptom as "normal", they went back to matching pistons to cylinders in 2004.
Are you aware of any recourse through GM to have this problem fixed due to poor workmanship?
The car was idling rough, so I thought maybe it has a bad oxygen sensor.
Can a bad oxygen sensor cause these bad noises?
Thank you in advance for your support.
Mar 13, 2009 at 10:48 AM
