1999 GMC Envoy Fuel Problem
143,589 MILES • 6 CYL • 4WD • AUTOMATIC
LBIZZLE
The truck runs good when it's just at idle, but when you step on the gas the truck want's to stall out. I did the oil change, and changed the fuel filter. I think it could be the fuel injectors but I'm not sure. What do you think.
Mar 21, 2009 at 9:16 AM
BRIAN 1
  • 1,030 POSTS
put a fuel pressure guage on it and see what it does when you step on the gas,fuel pressure might be ok at idle until you gas it and it might drop.should be 60-66 psi running.post back with any other questions.
Mar 21, 2009 at 12:11 PM
