1998 GMC Envoy P0300 Code
1998 GMC ENVOY
LAZAIR
Engine Performance problem
1998 GMC Envoy 6 cyl Four Wheel Drive Automatic 159K miles
The engine misfirines underload. It idles smooth. The odometer shows 159K miles.
Disconnected the MAP sensor while troublshooting. This resolved the misfiring and made the vehicle drivable. Obviously this is now masking the real problem.
When reving the engine in neutral gear, the misfiring occurs in the mid-range rpms. When this happens, an incomplete combustion smell eminates from the exhaust. (must not be lacking fuel- maybe ignition timing problem?)
Checked for vacuum leaks, none found. Measured vacuum at idle- 19".
While resolving a previous problem the following components have been replaced within the past 6 months: plugs, wires, distributor, rotor, fuel filter, fuel pump, fuel pressure regulator, new fuel injectors/spider, MAP sensor, EGR valve, new vacuum hoses, new ignition module, cleaned PCV valve.
OK, I'm stumped. Any further suggestions will be greatly appreciated!
Steve
Mocksville NC
May 14, 2009 at 11:10 AM
DOCFIXIT
  • 18,828 POSTS
Hi
The scanner your using does it have GM software or generic? Usually when unhooking MAP solves problem then O2 sensors are not responding fast enough and possible convertor issue. Does missfire appear on one cylinder more than others?
Let me know
Thanks for donate
May 14, 2009 at 1:04 PM
LAZAIR
My scanner is generic. I do not get any other codes but P0300.
The misfire does not sound like a one cylinder problem. There is no regularity to the "miss".
It is an over-all "stumbling" where the engine is acting like an air-fuel ratio problem. I'm assuming it is running rich due to the smell of the exhaust.
May 14, 2009 at 1:43 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Need to have diagnostic scan done to determine fault a code reader is not adaquate. You will end up replacing more parts with poor results. The P0300 is by far the most difficult code to diagnose even for the most experienced Tech.
May 14, 2009 at 2:48 PM
LAZAIR
Is my Actron CP9175 OBD II AutoScanner not adaquate?
May 14, 2009 at 3:19 PM
DOCFIXIT
  • 18,828 POSTS
Yes it is sold as a scaner but all it does is read codes. A diagnostic scan tool such as Snap MODIS, Pro-LinkiQ or Nexiq is the equipment needed.
May 14, 2009 at 3:42 PM
