How to remove a water pump
GMC C3500
MELESTER@EARTHLINK.NET
We are trying to remove a water pump from a 1997
GMC Suburban with a 350 engine. We have been at it for about 4 hours and it is still not off. We rented a "special tool" to help remove it, it doesn't work.
We are not sure which way the bolt turns (we think it is the same way as the fan turns, which would be to the left if you are standing in front of the car). It won't budge. Any suggestions?
thanks a bunch :|
Aug 11, 2007 at 11:54 AM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
All you do is get the pads, install them as usual! Anti-lock is an electronic brak control over the normal system...
Aug 11, 2007 at 5:50 PM
