1998 GMC C3500 Warm Start Sluggish
LINDAKISSACK
I asked this question a few days ago but did not hear a peep from you. Without a donation, I guess it takes a few weeks, eh? I have a 1998 GMC 3500 van with 140,000 miles on it. It starts ok the first try, but it seems when it gets warm it is sluggish in starting. I replaced the plugs, the fuel filter, and had an injection cleaning, but it still does it. What could be the problem?
Steve
Dec 21, 2006 at 12:41 AM
GARFIELD
  • 197 POSTS
You may want to test the fuel pressure to ensure that you have good pressure, also while you have the tester attached to the fuel rail you can remove the vacuum line from the fuel pressure regulator and your fuel pressure should increase, if it doesn't then you probably have a fuel pressure regulator that is starting to go bad. Good luck
Gary
Dec 22, 2006 at 10:30 PM
Suggested Repair
Test fuel pressure at the fuel rail. With the gauge attached, remove the vacuum line from the fuel pressure regulator; pressure should rise. If it does not, the regulator is likely failing and should be replaced.
Conversation Summary
The owner of a 1998 GMC 3500 van says it starts normally when cold but is sluggish to start once warm, despite new plugs, a new fuel filter, and injector cleaning. The expert recommends checking fuel pressure and confirming that pressure increases when the regulator vacuum line is removed, which would point to a failing fuel pressure regulator if it does not.
