Front end rattles on both corners without breaks applied
GMC C2500
WALLYCARLSON
I have a 2003 2500HD 6L 4x4 with 100K that when i drive on a dirt road have a heavy rattle in both front corners. It is more pronounced in the Left front. The rattles stop as soon as I apply the breaks. Do the caliper bolts wear the mount?
My other truck is a 2004 2500HD 4x4 Duramax with 95K and the left front is just starting to rattle on rough dirt just as above.
The intermidiate shaft is was a changed on the 2003 but never was a problem on the 2004.
Jul 2, 2007 at 3:28 PM
GBGTEXAS
  • 46 POSTS
[quote:71d7894545="wallycarlson"]I have a 2003 2500HD 6L 4x4 with 100K that when i drive on a dirt road have a heavy rattle in both front corners. It is more pronounced in the Left front. The rattles stop as soon as I apply the breaks. Do the caliper bolts wear the mount?
The intermidiate shaft is was a changed on the 2003 but never was a problem on the 2004.[/quote:71d7894545]
probably have brake pad shims that have worked loose. take the calipers off and make sure that the pads are tight.
Jul 4, 2007 at 12:03 AM
