Front brake caliper removal
GMC C1500
OLDAVE39
1999 GMC 1/2 ton PU, 5.3, 112,000 miles auto trans with ABS. What size allen wrench do I use to remove the brake calipers? An 8mm is too small and a 9mm is too big. Also a 5/16 is too small and a 3/8 is too big. Is there a special GM tool for this? This is the front, the back has hex head bolts. Thanks
Sep 20, 2007 at 11:58 AM
PUPCOM
Did you ever find out the answer to your question? I just ran into the same problem. Please email me at pupcom@yahoo.com if you got it.
Thanks,
Dan
Nov 3, 2009 at 4:28 PM
