2003 GMC C1500 Engine lilte on and engine missing
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALBERT HAMBLIN
Just saw your web site and up a membership, so this is my first time to use it.
Yesterday, my engine light came on and started blinking, then the engine started running rough, and after a few minutes, the engine light stayed on (no blinking). The owner's manual said it was either the engine missing cauisng an emissions issue.
Last night I installed new spark plugs. No change, stilll ran rough and light was on. This morning I took it by my neighbor's shop and discussed the situation. He suggested I replace the rotor and distributor cap. I just did this (using DELCO parts). Still no change, engine light is on solid when the truck is started, I drive it and the engine light blinks a few times then goes solid. It sound and feels like a cylinder is not firing.
Now I am going to disconnect one plug wire at at time, start the engine and see if the miss gets worse and to see If I have a bad plug wire.
In the back of my mind, I am thiinking O2 sensor.
What do you advise.
Apr 18, 2008 at 4:35 AM
  • 75,988 POSTS
You need to pull the OBD2 code/s from the computer to determine what's causing it-Autozone can do this for free and comeback with the code/s
The CEL being On means there's a problem with the engine management system-
Apr 18, 2008 at 4:50 AM
