I recently had both heads (cracked) changed on my truck because of overheating due to complete loss of coolant. After the work was completed the person that did the work told me that I needed to change the Crankshaft Positioning Sensor due to a code and the Check Engine Light was on. I changed the Sensor and cleared the code but the check engine light came back on within seconds. My Haynes Repair Manual says that you must do a "Crankshaft Position Sensor Variation Learning Procedure". Can this be done by me or do I have to take it to a dealer? If I can do it, how is it done.
Jan 23, 2008 at 5:57 PM
