1998 GMC C1500 replacing heads
1998 GMC C1500
SHAWNARODRIGUEZ69
Engine Mechanical problem
1998 GMC C1500 V8 Two Wheel Drive Automatic
what is proper tourque sequence for replacing heads?
May 2, 2010 at 5:07 PM
HMAC300
  • 48,601 POSTS
start at the center and work your way out. it's supposed to be torqued to a certain point then use a torque angle to tighten. but if you go to 65 ' # in stages like 40-50-65 then you'll be ok.
May 21, 2010 at 10:41 AM
