1998 GMC C1500 nois in rear end
TROY WIL
  • 1998 GMC C1500
  • V8
  • 73,000 MILES
I have a slaming nois coming from the rear end of the truck. When I stop. I was told buy a friend that it is play in my drie shaft. They claim there is a procegure to repair this.
Friday, February 29th, 2008 AT 9:37 PM
LWHEMPERLEY
THE NOISE IS MOST LIKELEY A PINION BEARING
IF IT IS A HIGH PITCH SOUND UNDER POWER
& QUITS WHEN YOU LET OFF. ALTHOUGH THE EXT.
CAB OR LWB HAS A DRIVESHAFT BEARING. THAT I HAVE SEEN (RARE) THAT WILL MIMMICK THE SAME
SOUND. MOT GM 10 BOLT REARENDS 88 UP ARE JUNK, SO MORE THAN LIKELEY IT IS THE PINION
BEARING. MOST SHOPS WILL RE-BUILD THE REAR END IN ANY GEAR RATIO FOR ABOUT $900 W/WARRANTY WHEN A TYPICAL SALVAGE YARD
REAR END IS ABOUT THE SAME PRICE W/ A30 DAY
WARRANTY.
Wednesday, March 5th, 2008 AT 11:28 AM
Related General Content
