1998 GMC C1500 Fuel pump
1234MREW
  • 1998 GMC C1500
Electrical problem
1998 GMC C1500 V8 Four Wheel Drive Automatic
were does the gray wire goes from the fuel pump to what? I put in a new fuel pump, but now I have no juice going to the fuel pump. Why? Can you help? Thank you.
Friday, March 27th, 2009 AT 12:58 PM
The gray wire goes back to the fuel pump relay and the fuel pump/oil. Pressure switch. Do you hear the fuel pump for a few secs-if not check the fuel pump relay and ECM B fuse.
Friday, March 27th, 2009 AT 1:10 PM
