Excessive vacuum in crankcase
169,000 MILES • V8 • 4WD • AUTOMATIC
MAT9245
I have truck listed above with a 350 and there is excessive crankcase vacuum and the Idle is high at 2,000 rpm, there was only one code for a misfire on cylinder four.
When I checked that one there was a good amount of deposits on it. I did a compression check with all being around 165 lbs except for that one which was slow to come up to 165 lbs. If you take off the oil fill cap when it is running (if it does not pull it out of your hand) it just about goes to a stall.
Any help would be appreciated.
Thanks
Jun 17, 2008 at 2:53 PM
2CARPRO JACK
  • 11,533 POSTS
Have you checked the PCV valve? It may be broken or stuck.
Jun 19, 2008 at 12:43 AM
MEMBER1234
Sounds like intake gasket is leaking on bottom side allowing cylinder vacuum into crankcase. That will also cause a misfire just as would an external vacuum leak on topside of gasket. Have a 1996 k1500 5.7 with exact same symptoms.
Jul 8, 2018 at 9:37 AM
