1994 GMC C1500 stalls when warmed up
ENG8285
  • 1994 GMC C1500
  • V8
  • 190,000 MILES
When warmed up my truck stalls. I start it back up and runs fine for a second then stalls again. Before this it would stall when I put the vehical in gear. If you could give some suggestions that would be great
Thank You
Tuesday, February 3rd, 2009 AT 8:35 PM
  • 109,885 POSTS
Hi:
Have you checked the fuel pump pressure?
Tuesday, February 17th, 2009 AT 1:32 PM
COUNTRY_GIRL
I had the exact same problem with my 1990 GMC. Once I started it and it warmed up, I put it in gear it would stall. It turned out I had water in my distributor. Changed that and it was good.
Monday, February 23rd, 2009 AT 12:29 PM
