Transmission problem
1988 GMC C1500 V8 Two Wheel Drive Automatic
I just replaced the throttle valve cable or also called detent cable in my truck now I'm having problems with it shifting from 1st to 2nd and to 3rd it wants to ride each gear way longer than it should and then it slams in to the next higher gear, I've adjusted the cable all different ways and it still shifts hard what am i doing wrong or is there a another problem I'm not seeing
Oct 19, 2010 at 3:17 AM
