1985 GMC C1500 truck idles too fast
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMMIRACLE
This truck just stared idling too fast. When it starts, it is fine, but once you touch the gas, the idle goes up and won't go back down.
If I take the air filter off, I can manually flip a lever down on the left side of the carbureator and the idle goes back to normal.
When I give it gas, the idle goes back up and stays.
How do I fix?
Mar 19, 2008 at 11:41 AM
D5NUKE
  • 61 POSTS
Try cleaning the throttle linkage with cleaner and a shot of wd40 to loosen things up. Your throttle in probable all gummed up and sticking. Let me know how this goes for you.
Mar 19, 2008 at 2:16 PM
