1976 GMC C1500 She acts like a slug
1976 GMC C1500
550 MILES • V8 • 4WD • AUTOMATIC
BOOMING_IRON
i recently replaced the entire powertrain in my truck, to include axels so about the only thing left from 1976 is the body. 2 weeks ago upon completion of the re-instal i drove it around for about a week everything seemed to running out standing. i went out to start her the other morning the was no fuel in the filter>>> i cranked and cranked till she started with a little help from carb medic. i got the carb. set finally (i think) and i think i may have a vacuum issue. when i put it in gear and take off she's loud and thunderous... then she chokes like no tomorrow... any ideas??
Jul 29, 2010 at 9:52 AM
Check the fuel pressure if its within specs if okay check the initial choke opening and the fast idle cam adjustment, also the fuel filter-could also be the heat riser not opening or the diaphragm on the aircleaner housing is not opening
Jul 29, 2010 at 10:30 AM
BOOMING_IRON
i had a grounding issue with my fuel tank selector switch, go figure you remove a little bit of dirt and it all works fine...
Aug 5, 2010 at 11:16 AM
