2009 GMC Acadia DTCs P0008, P0017, P0018
2009 GMC ACADIA
24,000 MILES • 6 CYL • AWD • AUTOMATIC
ZAINIDDIN
Scanner shows error DTCs P0008, P0017, P0018. What? How can I repair?
May 11, 2010 at 11:46 PM
2CARPRO JACK
  • 11,533 POSTS
Those are all correlation codes, meaning they are set when the PCM doesnt think the cams and crankshaft are timed properly.Since itis so new and low mileage, I would let the dealer handle this under warranty.Without a scanner to watch what is going on, it may be the crankshaft position sensor, but there is also a Tech Service Bulletin about camshaft end play which could affect the cam position sensors reading
May 13, 2010 at 1:16 AM
