Glow Plug Relay replaced still won't start
127,000 MILES • 2.9L • 4 CYL • TURBO • FWD • AUTOMATIC
STELLALOCKLEY
The glow plug light came on after I started the car its been like that for some time - then it started whereby I had to turn it over 2 or 3 times before it would start - so checked out glow plug and it had signs of melting !! got new one and replaced it. Now when you turn the key the glow plug light flashes on and nothing the car will not turn over at all - unless we use easy start - after that leave it run for a while and it will turn off and back on again no problem. Have checked the heater box and that's working. Checked fuel injectors but it only dribbles out so its as if its an electrical problem not letting the fuel through when turning the key.
Any ideas what it could be ? Thanks,
May 18, 2015 at 11:39 PM
STELLALOCKLEY
Think we found problem its the temperature sensor disconnected the glow plug works and car starts so will definitely know in morning when its stood over night.
May 19, 2015 at 3:06 AM
STELLALOCKLEY
No its not the temperature senor would not start with out the sure start again so if you have any ideas please let me know
May 19, 2015 at 5:56 PM
