Getting fuel to injectors
2003 CADILLAC CTS
170,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
L B DANIEL
My emc is not reading I know how to bypass it to start, but I had to disconnect the fuel lines for a repair. Now I need fuel pressure from electric fuel pump. Can I bypass the ignition -1 relay to start the fuel pump I do not see a relay marked fuel pump in the box.
Mar 12, 2016 at 8:56 AM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
try resetting security system first. The relay is under right rear seat fuse box.
Mar 12, 2016 at 10:28 AM
