Getting door code
230,000 MILES • 6 CYL • 4WD • AUTOMATIC
KAYBOLTON
I am told dealer can give code to door.
After dealing with dealers getting no where with lift gate, is there a way around the dealer?
Jun 22, 2018 at 1:22 AM
STEVE W.
  • 15,418 POSTS
Do you mean the exterior key less entry code that you punch in on the keypad? If yes then there really is not an easy way around it without either a good scan tool or the dealership. They can connect up and retrieve the permanent code in about a minute. You will need to bring the vehicle and proof of ownership and ID.
Is this a three door Sport model or the full sized five door? There is a different way on those but it does take a bit of work, and interior trim removal.
Jun 22, 2018 at 3:35 AM
BMDOUBLE
  • 1,139 POSTS
Pull back the weatherstrip at the driver side c-pillar panel and pull out on the panel and you will see the module with a sticker that has the number on it. A mirror might be necessary.
Jun 30, 2018 at 2:53 PM
STEVE W.
  • 15,418 POSTS
Depends on which model. The four door it is on that module, the two door it is behind the glove box and you need to remove the module to read the sticker.
Jul 1, 2018 at 4:20 AM
BMDOUBLE
  • 1,139 POSTS
Very true, but the one behind the c-pillar I use a mirror. Our IDS locks up frequently so I have to macguiver the situation or lose time and money.
Jul 1, 2018 at 8:39 AM
KAYBOLTON
I will let you know how it works out.
Jul 3, 2018 at 4:30 AM
