1992 Geo Storm engine replacement
79,000 MILES • 6 CYL • FWD • AUTOMATIC
ASPENVALLEY
I just swapped engines in my Geo Storm. AFter replacing the engine and all major electrical components, I started it up and let it run for a few minutes before preparing to time the engine. When I sut the engine off I noticed a large amount of Transmission fluid on the floor. It is leaking out the bottom through the drain port, but I cannot determine why. Any Clues as to what I may have missed that would cause such a large leak??
Jan 4, 2009 at 11:58 AM
VBOSS5764
  • 23 POSTS
[quote:d2420dba6c="aspenvalley"]Transmission problem
1992 Geo Storm 6 cyl Front Wheel Drive Automatic 79000 miles
I just swapped engines in my Geo Storm. AFter replacing the engine and all major electrical components, I started it up and let it run for a few minutes before preparing to time the engine. When I sut the engine off I noticed a large amount of Transmission fluid on the floor. It is leaking out the bottom through the drain port, but I cannot determine why. Any Clues as to what I may have missed that would cause such a large leak??[/quote:d2420dba6c]
What drain port?
Jul 9, 2009 at 4:47 PM
