1996 Geo Prizm
TYRONEWALLACE1
  • 1996 GEO PRIZM
1996 Geo Prizm 4 cyl Automatic
I was driving my 96 Prizm when I noticed the fuel hand almost on empty. The tank should have have atleast 1/2 a tank but I filled up the tank again. So once the tank was full, I began to smell gas. I had a fuel pump put on about 6 yrs ago. I checked under the hood and no gas is getting to the engine. I was wonder if this is the fuel pump again, relay or is it another problem.
Friday, April 25th, 2008 AT 1:21 PM
LEGITIMATE007
  • 5,121 POSTS
Well here is an easy check for you.
Friday, April 25th, 2008 AT 1:41 PM
MERLIN2021
  • 17,250 POSTS
Have you ;ooked under the back by the gas tank for leaks? And is the check engine light on?
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Friday, April 25th, 2008 AT 1:42 PM
TYRONEWALLACE1
Yes there are no leaks. The car will not start. The fuel indicator is on full.
Friday, April 25th, 2008 AT 2:00 PM
MERLIN2021
  • 17,250 POSTS
If you can smell the gas, your check engine light should be on, it should show a P0455 for evap system leak. If it's on have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on.
Friday, April 25th, 2008 AT 2:21 PM
MERLIN2021
  • 17,250 POSTS
BTW, is 6 years ago the last gas filter change too?
By now it's pretty well clogged.
Friday, April 25th, 2008 AT 2:22 PM
LEGITIMATE007
  • 5,121 POSTS
You said gas wasn't getting to the engine, thats why I gave you a pressure check to see where your problem might be
Friday, April 25th, 2008 AT 7:47 PM
MERLIN2021
  • 17,250 POSTS
If no fuel gets to the fuel rail, apressure test is useless! Check the fusues and relay for the fuel pump, turn key on and listen for the pump, it should run for 2-3 seconds. If you don't hear it, it's either the pump, or the wiring. That is if your fuses are good! Or your ignition switch, some models activae the injectors when ignition switch is tured on.
Saturday, April 26th, 2008 AT 5:42 AM
LEGITIMATE007
  • 5,121 POSTS
O'h, o.K sorry. Yes your gonna wanna check your fuse and relay first like merl said.
Saturday, April 26th, 2008 AT 6:35 AM
