1995 Geo Prizm
DAVEY1995
  • 1995 GEO PRIZM
1995 Geo Prizm
We changed the transmission this past weekend, and we got in it and took off. It shifted fine for about a mile then it acted like it couldn't pull. We turned it off and started it back and it done the same thing. Do you know what it could be?
Monday, September 14th, 2009 AT 7:13 PM
Check and test the TPS and VSS if okay could be a shifting solenoid/s problem
Monday, September 14th, 2009 AT 7:28 PM
DAVEY1995
Thank You! Could you tell me what TPS and VSS stand for.
Monday, September 14th, 2009 AT 8:15 PM
TPS: Throttle position sensor and VSS: Vehicle speed sensor-In electronic controlled transmission the computer uses these sensors input signals as an indication of transmission throttle and governor pressures-
Monday, September 14th, 2009 AT 11:07 PM
