I just replaces the brake shoes, springs, and wheel cylinders in both rear drums, along with a few brake lines. After changing everything and bleeding the lines my brake pedal goes to the floor when I try to stop and I have little to no stopping power. Even if I pump the brakes with the car on it does not build up pressure. If I pump the brakes with the car off the pedal gets firm after 2 or 3 depressions. I'm not sure what to check now, and as this is my only vehicle and us it for work am going a little nuts. Thanks for your help
SPONSORED LINKS
Friday, September 3rd, 2010 AT 7:20 AM
