Corolla wheel brearings are pressed in.
You must remove the knuckle and have a shop press out the old bearing and press the new one in.
You can save some money by removing the knuckle yourself.
You would have to remove outer tie rod, brake caliper and bracket, lower ball joint, pull axle out from bearing, remove strut and then knuckle.
SPONSORED LINKS
Wednesday, September 30th, 2009 AT 7:07 AM
