1994 Geo Prizm Bogging and sputtering
1994 GEO PRIZM
205 MILES • 4 CYL • FWD • AUTOMATIC
SALHER98
I have a 94 prizm and yesterday i was driving and the car died radio and all still on just the motor i coasted off to side and had some issues starting car back up then it did and it was sputtereing alot so i sat there trying to get it to idle correct and finally it did but as soon as i acccerlerate and to much air gets in it bogs out or dies i had to drive very slow and still am it is taking forever to get anywhere and i am starting to get weird noises it happend last night
Jun 13, 2010 at 10:48 AM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 14, 2010 at 7:47 AM
