HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Geo
Prizm
Drivetrain
Transmission
Fluid
1993 Geo Prizm
CONNORSHANA
MEMBER
1993 GEO PRIZM
1993 Geo Prizm Manual
What happens if you put transmission fluid in the engine instead of oil?
Wednesday, August 12th, 2009 AT 5:11 AM
MMPRINCE4000
MECHANIC
You can ruin the bearings in a short time, both main and rod bearings, you will also get blowby through the rings, since ATF is not as viscous at oil.
Drain and change ASAP, then again in 25 miles.
Wednesday, August 12th, 2009 AT 9:20 AM
Please
login
or
register
to post a reply.
Related Transmission Fluid Content
1996 Geo Prizm
Does This Car Require Transmission Fluid, And If So, Where Do You Put It In Or Check It?
Asked by
auntstepha
1 ANSWER
1996
GEO PRIZM
1995 Geo Prizm Transmission
1995 Geo Prizm My Car Is Having Some Slipping From 1st To 2nd And 2nd To 3rd. There Is No Grinding Noise. The Transmission Fluid Is...
Asked by
cris51534
1995
GEO PRIZM
1994 Geo Prizm Linkage
How Can I Switch My Linkage Around.I Recently Replaced The Transmission And The Salvage Yard Didnt Give My The Specific Year That I...
Asked by
richardreala
1 ANSWER
1994
GEO PRIZM
1990 Geo Prizm Tranny Removal
Transmission Problem 1990 Geo Prizm 4 Cyl Front Wheel Drive Automatic Does The Tranny Come Out The Top Or The Bottom?
Asked by
Don Alcorn
1 ANSWER
1990
GEO PRIZM
Car Info!!
Why Is It Hard To Put My Automatic 1997 Geo Prizm Into Drive?
Asked by
hayleylinn2010
1997
GEO PRIZM
VIEW MORE
How to Service a Manual Transmission - EASY!
How to Service the Transmission
Transmission Service Ford Super Duty F-250
