1992 Geo Metro Battery Related
THINDS88
Electrical problem
1992 Geo Metro 4 cyl Front Wheel Drive Manual
my geo had started up a few months ago after witnessing that my wire was loose to my coil. It went down shortly after It did come around and I replaced those wires. what could It be the reason for It not starting now?
Oct 2, 2009 at 11:25 AM
  • 75,988 POSTS
You probably don't have spark do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark?
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 2, 2009 at 11:36 AM
